Having first aftermarket crank balanced and want to confirm what I need to bring to machine shop or other advice if recommended.
Crank is a Eagle cast 360/3.58 stroke supposedly at 2050 bobweight (I know - a junk crank but only need around 380hp & it was free to me)
The new KB-107 pistons have rings installed, are pressed onto rebuilt/resized stock rods w/caps+bearings & ARPbolts+nuts all together already. I had planned to bring these 8 assemblies along w/crank to the machine shop.
This is an internal/neutral balance setup (right?) so I shouldn't have to bring Summit balancer or B&M flexplate.
I want to get at least a static balance - figured this motor/crank isn't worth the extra money for dynamic balance job for the little hp that I'm expecting.
I am also hoping this combo will balance w/minimal cost as I will buy new rods before I put Mallory in that cheap cast crank.
Opinions/Advice?
TIA
