Had same thing happen when i installed centerforce clutch. Remove that big OC spring and you won't have anymore problems. Be careful removing that big azz spring. You will still need a little spring to bring the pedal full back.
Thank you. It seems like the guy I bought it from had the same problem as I did.
Thank you to everyone who responded.
