Could you please list the part numbers of everything you used to convert the brakes over to disc.
Well all i can tell you is the part number of the brake rotors from Autozone but you really don't need that part number cuz any rear brake rotor from a 2005 nissan Maxima will work, then the caliper bracket from Aerospace Components for a Mopar Rear end they just have that one, and the calipers are old wilwood solid rotor caliper Dinalite, thats all you need to know to get the same setup on your car,
remember my axles are custom moser ones so you may need to tweak a little the brake rotors to fit your specific axle but it will be very easy to do so with a carbide bit on your die grinder, also my axles are 2.5 offset just like factory so there should be no issues with the depth on the brake rotor and anyway the caliper bracket is adjustable there!
