Bumpsteer
When you have this the toe is out causing the tires to hit the ground turned out. Then they tug and try to jerk back. The more slack in your steering components and the more it does this.
You can limit travel. This limits some of the characteristics that can't be fixed on a stock front suspension.
Career best 8.02 @ 169 at 3050# and 10" tires small block power.
