Comp Cams has a baseline SS cam with similar specs. See the attached PDF. I'd guess around .750"-.800" lift. You should be able to get a rough idea by measuring the lobes with a caliper. It won't be perfect, but probably within 10-20%.
6018572-CCHemiCams.pdf (207 downloads)
Floyd Lippencott IV
