I have already disconnect all belts (there are only 2) and the squeak persists. I've put my head around every square inch of the engine looking for something minor rubbing somewhere. The most obvious location for the squeak is coming right out of the carb.
try and spray some wd-40 around the base of the carb, notice if the idle changes and or sound changes. spray also around the intake to head area. Bob
