Quote: I used to have a 91 Daytona and the speedo acted up. Sometimes it wouldn't work, sometimes it would. Sometimes while decellerating from 70mph the speedo would stick on 70 for a while before dropping to normal. I put a speed sensor in it and didn't have any more problems. Hope that helps!
Don't wanna hijack, but I was gonna post this question as well. 97 Neon, same symptoms as above,except for the sticking. Is it worth the time to remove the sensor and clean connections, or should I just replace it?
You should check for fault codes first. If there is one it could be a sensor. Also verify if the odometer does not work at the same time. If it does work and the mph needle does not the problem could be in the speedo head/cluster.
