no need for ammeter mods, as far you make the right upgrades and power splices location
yes, will need run better and thicker wires and clean conections.
http://www.dodgecharger.com/forum/index.php/topic,33574.0.html
http://www.moparmusclemagazine.com/techa...ator/index.html
ALTHOUGH the problem is not really the bigger output capacity, like the poor iddle charging capacity what produces the high peaks and heavy needle flicks, coming and going... just that OF COURSE a higher output capacity will increase the output at iddle by default.
With a Charger born in Chrysler assembly plant in Valencia, Venezuela
