engine off,screw out,carb cleaner,spray,with air gun,blow it into the hole
cleaned a bunch this way
cut the pressure down to 40-50 lbs
when I soak a carb that air pressure is the trick to cleaning one good and all the tiny air passages
but have had good results on the car with just air into the airbleeds
