From a previous thread I've learned that the passenger side idle circuit on my Edelbrock Performer carb is probably gummed up. (Adjustments to idle settings on that side of the carb make no difference in idle speed or vacuum)
It was suggested that I remove the idle screw and spray some starting fluid in it. I noticed my can of starter fluid says "do not spray in running engine".
So help me pick an option:
A) with engine off, remove idle adjust screw and spray with starting fluid and let it sit for a few minutes
B) With engine running, remove screw and spray
C) With engine running, remove screw and spray with carb cleaner instead.
