If you use the intake gasket with the end pieces the tabs go through he little holes in the end pieces to hold in place.
If you use silicone you can clip them off or leave them the intake should seal either way..
Good answer...
I've never had any trouble with leaks, but I always find myself wondering "how did I install these the last time????"
I always like to glue the pieces down (with silicone) and let it sit overnight anyhow.
I'm going to make it a point to just "cut them off".
Thanks!
"Robots building robots.... now that's just stupid!" - Will Smith in the movie "I, Robot".
'71 Demon (340/727)/'69 Charger (383/727)/'65 Barracuda (273-2V/904)/'66 Coronet (340/727)/'86 Dodge Aries (2.5L)/'78 Dodge Aspen (318-2V/904)
