No, they don't. The 4876311's exhaust port location is identical to a standard Stage VI, which means it's about .4" wider and .4" higher than an OEM head's exhaust port. That's why you have clearance issues w/ the torsion bar.
Yes, I'm afraid you're right. My own fault for missing this, but the information sheet that came with the heads clearly says "exhaust ports are raised".
1968 Charger R/T
2015 Charger R/T Scat Pack
2017 Durango Citadel
