AndyF hit the nail on the head there. Your new fuels with ethanol in them and possibly the water b gone you used causes the varnish in the fuel lines and tanks to become brittle and flake off. When I moved to the midwest for a year I was having to pull and clean out my carb every couple of weeks! Looks like brown sugar. Also you might want to try moving your filter away from a heat source!
