just can let it idle long in the garage cause of the fumes. (quote)
Maybe your garage is too rich try adding some air flow in the garage.
( a small joke)
How does it run outside?
I was thinking the problem was while sitting in the car. You should not run the car inside without proper ventilation. AS IT CAN KILL YOU!
Maybe try hoses on the exhaust pipes like the shops do.
