Thanks Mike. I was actually thinking of you when I posted, as I've seen you tune in when Keisler questions are asked.
The kit is $4500, so about $1000 off. It's for a small block, and i was using it behind my 6.1.
I'll send Gene a message and see what he says but
I'm guessing I'll have to be the bad guy and back out now.
Depending on what your paying for it, and the additional items needed, plus reworking the shifter location/case to fit your 69 B Body, a new kit from Keisler might cost you the same?
The pedals are incorrect for your application, the drive shaft will be too short, the transmission mount is incorrect, the case/shifter location will need to be modified, plus you'll incure shipping costs both ways,.....add up the costs and see if it's still a deal?.......talk to Gene at Keisler to estimate the costs involved,.....plus you haven't mentioned wether or not the application is from a smallblock or BigBlock,...I assume your Runner will be Big Blk? more possible pcs/$$$...If this is a TKO 500 5spd, I wouldn't consider it behind a BigBlk
Mike
