Depending on what your paying for it, and the additional items needed, plus reworking the shifter location/case to fit your 69 B Body, a new kit from Keisler might cost you the same?
The pedals are incorrect for your application, the drive shaft will be too short, the transmission mount is incorrect, the case/shifter location will need to be modified, plus you'll incure shipping costs both ways,.....add up the costs and see if it's still a deal?.......talk to Gene at Keisler to estimate the costs involved,.....plus you haven't mentioned wether or not the application is from a smallblock or BigBlock,...I assume your Runner will be Big Blk? more possible pcs/$$$...If this is a TKO 500 5spd, I wouldn't consider it behind a BigBlk
Mike
