That 6 wire plug maybe the blower resistor plug for the heater. Have you checked the fuses to see if you blew one while installing the radio. The lighter is grounded by the dash it's screwed into unless it has a tab at the base of the housing. You bought yourself a real beauty of a project didn't you.
