It was pulling right at first, but not nearly to the extent that it was, it was a very, very slight pull. In fact I'm not even sure that it wasn't just my mind telling me it was pulling because that's what I expect out of it now. If that makes sense.
But I agree, I'm still not 100% convinced I've fixed the root problem. But, I definetely did fix a problem. After watching the left brake with the drum off it was obvious that the left adjuster was not functioning properly. This is also reinforced by how the brake pedal feels now.
I'll get it out on the road sometime today and I'll post the results.
