Hi Gentlemen,
I need to replace the seal in my axle at the passenger side as i'm getting oil into the brake drum.
I realize i need to set the end float at this side of the axle when doing this job.
I have a dial gauge and magnetic stand which i'm ok to use.
If i'm reading the manual ok i think i need to set up the bearing with between .005 and .012 lash.
Would you guys agree with this?
Any other tips please?
This is the first time i've been inside my axle.
Many Thanks
Simon
P.S.
Just to make you guys feel good about driving a 'gas guzzlin' V8....Petrol(gas)Is now £1.20 a litre in the uk
