Nope, trans does not match the vin. Oh well. Not surprised, the tranny probably came with the 440 that was in it. I'll see if those two at least match when I get it back from the machine shop. So I guess there is no way of telling if this is the vin for this car at this point?
Here's the number I found under the trunk channel. Does this look like the right number? (the one I am looking for). This does not match the fender tag.
That is the part number of the panel that makes up the trunk rail. You shold have the VON number stamped somewhere on the trunk rail and core support that matches the numbers on the lower right of the fender tag. They will be larger than the number you posted and will be stamped MUCH lighter into the panel. It sometimes requires ALL the paint removed from the lip to be seen.
JB Rhinehart, Realist
A-Body's RULE!
