Thanks to Steve from Hybrid Fiberglass...better known as Paint It Black on this board. Helped me out with pictures and talked me through what I should do. With a little imagination and some TLC, I turned his Stage 5 Dual Quad Air Cleaner into a 440 Dual Quad Air Cleaner. I spent last week cutting out the center holes with a dremel and a blade and then 2 days this week fiberglassing and resetting the holes where I need them. They are gonna stay gray for a while until I get the black and orange paint overseas (most likely gonna be painting it in August) but I think the air cleaner looks pretty killer in my engine bay. Now I have to mock up the correct linkage and get the fuel line going on to the setup...I hope I dont need another Air Cleaner, but if I do...I know where I am goin'
1st Pic : What I need to Cut and re-insert
2nd Pic : All cut away and set in with Duct Tape
3rd pic : All fiberglassed in place
4th Pic : All fiberglassed in place
5th Pic : All primered with PPG DP40
6th Pic : The original look in my engine bay
Note: I have 1" carb neck spacers between the Air Cleaner and the carb for linkage clearance and I am also going to try to stuff 1/4" to 1/2" phenolic spacers. I have over 1" clearance on the top.
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
