Rug,
What epoxy do you like to use? Some of the clear two part epoxies don't like gas I believe. I have a gray colored two part machineable epoxy that I think works better.
I have used JB Weld or JB Quick.
Clean with alcohol and apply carefully with a tooth pick. If you get too much on the outside it won't fit into the carb base.
Machinable epoxy? What is that? Sounds like a neat thing.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
