Removing the torsion bars is easy. The lower control arm bushing is a pain. Cut or press it out. The upper control arm bushings are pretty easy, a good size bench vise will press them in and out very well. The upper control arm ball joint requires a special socket and LOTS of muscle (cheater bar leverage) to unscrew.
you also have to break loose several tapered rods on the ball joints.
