I don't think I will make it 10/11, due to work. Which is a good thing, since whoever employs me is my sponsor so to speak!!
I race there, the one thing that is weird/I don't like is you drive around a steel plate or board, (used to shield rocks etc. from cars in line behind burnout box)pull up to almost the starting line. Then BACKUP into the waterbox. It can be a little tricky.
They treat the racers good. But it puts the HOT in hotlapping in the later rounds.
Don
