Hey Kirby, we hope to see your t/a this weekend at the show. If you had smoke from wiring then you should be able to find where it burned then see what color the wire that burned was and go from there. I have a wiring diagram at home if you need it, I can scan it and e-mail it if you need it or you should try to get on of the colored diagrams from classic car wiring, maybe someone on the forum can send you one of those. Good luck!
Al & Sheila
