w a screwdriver jump from the large batt terminal to the brown solenoid wire on the starter relay and if it cranks the batt/cables/starter are OK. then see if the yellow "ign" wire to the starter relay has fire when a helper turns the key to "start" & if so see if the neutral safety switch is grounding the "grn" wire on the starter relay when in Park, neutral or w the clutch depressed
