you got to do the wagon. A nice boosted 360 you could drive to the track run good numbers and drive it home. For a 1st build I'd do a blow thru S/C set-up. You can buy complete set-ups for $3200 or make your own for around 2. The best thing is you won't need crazy heads, big cams, high stalls or tall gears to run.
[IMG]http://i66.tinypic.com/pui5j.jpg[/IMG]
Coming soon!!!!
