i'm doing the same thing with a 360, using an eddy rpm airgap, definately the better intake for up to 6500-7000 and torque, stock intake height is around 4.5 to 5", rpm airgap is 5.35", so you would have to get a lowered air cleaner base(eddy or such)and fab it with a repro shaker base plate to lower the base plate about the same amount as you raise the intake, it can be done
