A buddy broke your stroker cast crank...
https://board.moparts.org/ubbthreads/showflat.php?Cat=0&Number=5853870
... and want to buy a new forge crank and do more strong the block bottom end.
we have some doubts:
Is it necessary to change the main caps? if so, what aftermarket main caps brand recommends, 2 or 4 bolts main caps (the block it's a 360 LA)?
Do you consider the use of main caps girdles?
Can use maincaps girdles with a windage tray... fit in a stock pan?
Thanks,
pd:excuse my poor English
'70 Dodge GTX sb 418ci (Early A-body),
Lunati Solid cam 270°/243°@.050/.548", Edelbrock Heads, Weiand X-CELerator,
Holley Terminator EFI, Tremec 6 sp manual, 3.90:1, TTI Headers.
