At WOT the rod should be allmost all the way back. You should have about an 1/8 inch play. return spring will hold it forward. This is why you need to adjust it right from thre beginning. If second rod is not adjusted properly then the geometry will be off. Set it up right the first time and your done. May only need a minor tweak to get the shift point where you personally like it.
