Hello,
I would like to replace my fuel tank sending unit on my '70 B-Body. I wanted to know if I need to buy anything additional other than the unit? Will I need special gaskets or seals when doing the replacement?
Also, if anyone has done this before -- Do you have to drain the gas tank (or remove it) in order to do this procedure?
Thanks very much!
