Hi finding I have alot of toe in change when the front wheels move throughout their travel. The tie rod ends on the dakota rack are about 2 inches longer then the lower control arms. Anyone got any pics of what the did to correct this. I was thinking of getting another set of minivan knuckles and machining off the arm going to the tie rod and making a new one 1.5 to 2 inches closer to the middle of the car to try and make the tie rods the same length as the lower control arms. Maybe bolt it to the lower wheel bearing bolts.
