Isn't the door key the same on that model, pull the door cylinder and take it to a lock smitha nd he car cut you a key. Another option is to drill the cylinder out from the key slot using progressively larger bits until you release the tumblers. I believe removing the wheel and pushing the pin wont release the ignition switch until the key is turned.
Careful, your character's showing!
