Re: 727 fluid- What to use?
[Re: Mattax]
#629468
03/06/10 09:28 AM
03/06/10 09:28 AM
Posts: 1,285 Pacific NW USA
CompSyn
Pacific NW USA
Right, to clarify, I'm not referring to the newest of the new DEXRONŽ VI, MERCONŽ LV, SP low viscosity ATFs; don't run those in your 727.
WRT the Dex VI we'll have to agree to disagree on that one. Your competitors who make Dex VI specifically state it is backward compatible to Dex II and Dex III.
As far as I can tell, the differences in the ATF's friction modifiers are going to effect the way the clutch packs and bands grab. We're talking about what is happening for that brief moment while the clutch is slipping. That timing is critical in an automatic. However, as someone pointed out, it s hardly the only factor. Anyone who has modified their 727 ought to use the fluid characteristics their clutch supplier and/or builder recommends. Anyway, its the friction modifiers that result in Dex VI working fine for a plain ole 727 and ATF+ not working so well.
One advantage the Dex III had over II, and all the newer ATFs have over Dex III is the lower, low viscosity. An analogy to motor oil is that its like having a 10w-40 synthetic instead of a 20w-40 conventional oil. It means that even below operating temperature, the ATF acts more closely to the characterists it has when at operating temperature. For some applications, that's almost irrelevent, others its very important. For short drives and autocross, its important. If you're pulling to the line and loading the torque coverter, the fluid will be at operating temp real quick if it wasn't already.
It's true, they tell us the latest Dex VI variant is backwards compatible with the Dex's before it. Let's hope their right, remember when they told us that API (SM) rated motor oils were backwards compatible with all other previous API rated oils? Many would disagree with that one today.
One thing is sure, there are some differences in viscosity, for example:
Synthetic Type F: 7.1 @ 212F
Synthetic Dex III: 7.6 @ 212F
Synthetic Dex VI: 6.0 @ 212F
Viscosity of the same ATFs cooled down to 104F
Synthetic Type F: 41.3 @ 104F
Synthetic Dex III: 38.9 @ 104F
Synthetic Dex VI: 29.8 @ 104F
Viscosity of the same ATFs cooled down to 32F (freezing)
Synthetic Type F: 205.3 @ 32F
Synthetic Dex III: 172.1 @ 32F
Synthetic Dex VI: 128.3 @ 32F
