I am narrowing my 8 3/4 rear and tacked on the new spring pads and put it in the car for a trial fit before I get too far. Well the locating hole in the new mopar performance spring pads are larger than the originals causing a loose fit on the springs locating pin. Will this cause any issues? Can I use them? Should I find some spring pads with the smaller hole?
