big mistake just using silicone.
Especially if you use too much and it begins to break loose and plug up the pickup.
I used silicone last year between my windage tray and pan and tried to be careful not to overdo it and still had some sticking in the pickup when I tore it apart at the end of the year.
This year I am trying the fel pro rubber coated gaskets and glued them on with copper coat prior to installing them.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
