I don't understand the people who say an 99 hemi can't be turbocharged.Yes you can't or don't want the rotating assembly the prostock guys use ,that given -I have a new crank ,rods and pistons and thick wall wrist pins that were made to my specs and see no reason this engine will not make power,the only thing I don't like is the block ,but it is a carbon block .They twist these engines to 10 thousand rpms and then drop the clutch and they seem to hold up petty good.Maybe I'm hard headed but I expect at least 2500 plus horsepower out this thing and that is not dreaming .If you are going to turbo any engine count on changing just about everything but block and heads ,and buy the best for the intended horsepower you plan and be honest in your goal and then go do it.If you listen to someone tell you it can't be done ,your never know if it will.
