it depends if you had your car acid dipped as much as his
If you are spending the money to acid dip a entire car, I would not waste my money on a mild steel cage. Cm would be the only choice then.
Jeff
yeah i dont see the reason to acid dip the body and then add the weight right back with a mild steel cage.
i think the cage will work unless i can get someone else to just do the whole job for a fair price.
