I have had two D and two E 15 incher trailer tires on my 8800 lb(loaded on the axles) Pace 24ft. trailer for the last four years I do use it regulary and keep the cold tire pressures about 5 lbs above the recommended pressure on the tire siewalls I had two blow outs at one time and could not get another two E rated tires at that time
