Quote: Here's the type of baffling thats inside (this one doesn't show a sump)....and it is 19 gallons...the same size as the stock tank.
When I was making fuel tanks for Chrysler I use to make a baffle or baffles with a extruded hole in the baffle to give it strength..... but your set up looks great
