I have a set of untouched j heads and its a la. Would magnums be better. And cast stroker would be fine wheres the best place to buy one?
I'm asking the questions along with you. I'm in about your same situation.
Question: Least expensive path to 450 hp that's easy on the valvetrain/parts, not a lot of maintance, and a small enough cam that not going to lug and lope real hard?
And the parts you have lying around do factor into the budget. What size valves are in those J Heads you have? That may factor in the decision making.
