I tried the fel pro kit with my .040 over 440 and it does not work, I had to order fel pro FPP-1009 head gaskets.
When you say it does not work, is that due to the bore size. I only ask because after some research, the head gasket that comes with the felpro gasket set (FEL-KS2110) is the 8519PT1, which is what I removed from my engine. That gasket has a 4.500" bore. The 1009 has a 4.410" bore. I wonder what head gasket came in your gasket kit.
