Tore down the 440 I just bought and it actually shows some pretty good promise. Pistons are .040 over flat tops and the cylinders still have an appreciable amount of cross hatching on them.
My question is, I now need a gasket kit for this engine.
What bore diameter do I use for a .040 over 440 (4.360" final bore)? Does fel-pro make a good gasket kit? I found the one on summit to be 55 bucks, but that comes with standard bore head gaskets. Should I just piece this together a gasket at a time?
