Was the same as any 440/4 converter..11.75 and the stall on mine is 1850-2000rpm . The HEMI cars had the higher stall converters as well as some small block and 383 cars.
Even the externally balanced converters?
I don't believe there were any in 1970.
Both 70 440 4bbl HP and 440 6PK are externally balanced.
