It is a huge undertaking to maintain a solid lifter cam. Especially if your a part time driver/streeter cruiser type. If so then go roller or hyd. Solids take time to set up and for the most part you have to inspect!
I run an Ultradyne .577 solid in my 440/498 stroker. Had I built this engine I would had gone roller but the power now is tremendous and scary fast. Not many "cams" have it as solids do..
go see a few old school builders and ask away!
Im stuck with what I have for now but I tell you, this cam is crazy! set up right you can get huge power...
