I am 95% decided to go with the Lunati 60305 Hyd cam in my motor..
Here is Combo....
'71 440 Block .30 over
All neccesary machine work/ fully balanced
Block square decked
Ross 99539 pistons/ 2.065 Comp. Height
New Scat Rods
Lunati 60305 cam/lifters
440 Source stealth heads/Crane Ductile adjustable rockers, bushed by RAS/ Bananna groove shafts
Holley SD intake
Holley 850 DP
1 7/8 headers/ 3" exhaust w X pipe
MP Ignition
3.91 gears
Windage Tray
I have gotten numerous suggestions to go with the mp.557 solid cam. Here is my dilemma. This being my 1st high performance build I have "0" experience with a solid cam.
Can someone in a nutshell explain how to adjust valve lash. Is it relatively easy to do once figured out? Does motor need to be running while doing this?
I don't have my FSM handy, does it go into this in there??
Chuck
