The fine lines fit the 8.75 that was in the car (70 Charger) but the rear I was putting in was from a 68 RR. I just cleaned up and re-used the original lines. (68 rear) The "T" block is in a different place. Now I have to ask myself, do I buy a hose for a 70 Charger or a 68 RR???
depends , is the body line stop in the same spot for a 68 rr as a 70 charger .
they did the same thing on a bodies , maybe the same year , moved the T block , i redrilled and tapped the axle to put the line in the proper place for the car i was working on as i am pretty sure the line is listed as different also
No idea but I do have access to a few nice 68 RR's . I'll have to do a little looking.
