no use being stupid unless you show it.
I do not know how to take the axles out, and if all I need are Mr. Gasket studs and they will pull into place just using the lug bolts then that would be the better way for me to go, no cost of drilling out axles to fit the studs that would need to be pressed in. I just need to know from the guy who recommended the Mr, Gasket studs if they will indeed pull on with the lug.
If they will not, I may as well drill mine out,
and have the moroso studs I have pressed in, and pay to have axles taken out. I did ask in this thread, if some one could refer me to a site that would show me the way to remove the axles, but I had no luck. I am pretty good mechanic wise just do not have the knowledge of how to porceed.
