Quote: Those calipers have very small pistons. You need to run a 15/16" bore master cylinder.
Also, they will improve once the pads are bedded. For some reason SSBC provides the wrong master cylinder with the kit. the 1 inch boar on the supplied master does not help the situation. Just press harder
