Re: solid roller tell me
[Re: RyanJ]
#581451
01/14/10 12:20 AM
01/14/10 12:20 AM
Just be careful over camming the small port. In the end you may loose more down low, then you gain up top...
Yes.
The 1st cam you mentioned would definitely be on big side for your compression/heads/converter. I just replied to your PM from other day. Sorry been swamped W/ work & taking while to get PM's emails/calls done lately.
That Crower you PM'd me about would not be bad, it's still hair small but, step in right direction.
it sounds like the same type of reply i gave. about 10 degree's more than the one you pm'd me about will do the job very well based on the info i have of your combo.
